2010 HHR 2.2L Flex WHAT OIL
Old Nov 11, 2010 | 09:56 AM
willy4820's Avatar
What oil do you suggest for 2010 HHR LT with flex fuel 2.2L engline? I believe 5-30 but synthetic or good grade standard motor oil? Will change oil every 4500 miles after first @ 3000 miles. Any issues with Fram filters?
Thanks in advance
Old Nov 11, 2010 | 10:15 AM
Later's Avatar
I believe this has been extensively covered.
You may have to spend some time looking but it will be worth your while. There is a wealth of information for you to find here in these forums.
Old Nov 11, 2010 | 04:39 PM
BlackknighT's Avatar
Welcome & enjoy the ride.
Make use of the search function on the upper right of the screen. Click on it and type what your looking for. Putting in 2010 is not necessary-probably just "oil change" will do...
Old Nov 11, 2010 | 04:47 PM
ChevyMgr's Avatar
Three letter words will not work in the search function, so searching for oil will give no results. Go to the Maintenance Forum for an abundance of threads on this subject.
Old Nov 11, 2010 | 04:49 PM
Oil is only 3 letters and won't work for a search...... Better to just browse around as there are several discussions about oil, shouldn't be too hard to find.
Welcome to the forum!
EDIT: ChevyMgr..... You type faster than I do.......
Old Nov 11, 2010 | 05:17 PM
DOH! Sorry bout that... Learn sumtin new iz did...
Old Nov 11, 2010 | 06:41 PM
LawDog88's Avatar
Personally, I return my vehicle to the dealership at which I bought it, and have it changed there. That way, if they break anything while changing the oil, it's covered and does not void the warranty in any way. Yes, it may be a little more, but it's worth the reassurance to me.
Old Nov 11, 2010 | 07:49 PM
ChevyMgr's Avatar
Old Nov 12, 2010 | 12:04 AM
Personally I trust myself more, so I know it's how I want it..
And I don't just pull the plug & drain, I'm looking at everything everywhere..
Old Nov 12, 2010 | 02:26 AM
IgottaWoody's Avatar
To answer the real question...just because it says flex, it doesn;t mean anything special in the oil department..use GM suggestion or better..the rest is in the thread search
