ac compressor clutch
Old 03-24-2019, 10:40 AM
Cliffs51's Avatar
Has anyone successfully replaced the ac compressor clutch with the compressor in the car and connected. Id like to change mine without opening up the system. Thanks
Cliffs51 is offline
Old 03-24-2019, 04:14 PM
Cat Man HHR's Avatar
You can change just the clutch and not worry about opening the system.
Question is ? Do you have the correct puller/installer for it ?
Cat Man HHR is offline
Old 03-25-2019, 03:26 PM
Cliffs51's Avatar
From looking at youtube looks like i need snap ring pliers and two different types of pullers. Am I right? Is there enough room to use the pullers? I think i may replace the whole clutch instead of just the bearing.
Cliffs51 is offline
Old 03-25-2019, 03:45 PM
You will at least have to disconnect the compressor and pull it up with the hoses attached to give yourself room to work. Once you remove the center of the clutch with a puller (yes you might need that snap ring pliers) you can then remove the 4 bolts and remove the coil magnet. The bearing is part of the coil assembly. Buy a new assembly and save the shims from the old one if there are any. That will set the air gap between the clutch face and magnet.
I'm sure if you go to AutoZone or Pep Boys or Advance you can rent the puller group.
Good luck with the repair.
Old 03-25-2019, 07:37 PM
Cliffs51's Avatar
Thanks for the help 😁
Cliffs51 is offline
mistermike
09-11-2008 10:22 PM
Lone Ranger
08-09-2007 10:08 PM
MCANAW
05-16-2007 06:43 PM
coolsurf
09-03-2006 11:03 PM
jerij
05-30-2006 10:58 AM
Quick Reply: ac compressor clutch
