Air filter cross over
Old Jan 15, 2020 | 02:34 PM
It draws air from the engine compartment, so it's not a cold air intake.
Flyinmech's Avatar
Intake noise ? But easy to get at and change
Old Jan 15, 2020 | 03:05 PM
Cat Man HHR's Avatar
Originally Posted by Flyinmech
I have seen some K&N and other brands use this design. My concern is that it open with no box.
I agree.
Why suck in hot air when you have a factory cold air box.
If you want insulate the box on the car to keep radiant heat away.
Old Jan 15, 2020 | 03:07 PM
Boy are you lazy.
You going to change this thing every 10K ?
Old Jan 15, 2020 | 04:51 PM
Yeah... That would be considered a "hot air intake"
Old Jan 15, 2020 | 05:33 PM
Yep. Nothing about that design makes it a "cold" air intake. I especially like how the filter is set at the back of the engine compartment. Right where it can suck in all the heat radiating off the exhaust manifold. And the bracket that mounts to the body. Uhh, what happens as the engine rotates in it's mounts under a load.
Old Jan 15, 2020 | 05:56 PM
Flyinmech's Avatar
Ok, whatever I get, K&N or ? How does this affect the MAS sensor ? Any problems?
Old Jan 15, 2020 | 06:50 PM
I’ve had the K&N FIPK and the drop in filter from them, both are about the same
The extra intake hose helped
Old Jan 15, 2020 | 07:35 PM
Flyinmech's Avatar
Thanks, Blue. So, you had no issues with the mass airflow sensor or codes ?
Old Jan 15, 2020 | 09:18 PM
Thanks FMG- That is kinda what I thought.. Waste of money.
