Battery replacement
Old Jan 17, 2011 | 11:11 AM
RICK167448's Avatar
Battery replacement
My hhr was born in april of 2007. I have 30,000 miles on my car. When should i consider replacing the battery?
Old Jan 17, 2011 | 11:37 AM
jay loukakis's Avatar
battery
Mine is 2006 2lt with 48542 miles and is still strong.
ekotecki's Avatar
I would say no. Heat is the biggest culprit for batteries. With the battery in the lower back end you should have no problem. Checking it with a meter is the best bet.
Old Jan 17, 2011 | 11:43 AM
TiggersHHR's Avatar
I have over 62,000 miles on mine. Accidently drained it once and had to jump start it. That was around 36,000 miles and it is still going strong.
Old Jan 17, 2011 | 09:49 PM
Later's Avatar
My 99 Ranger still has the original battery. Turns the engine over just fine.
Old Jan 22, 2011 | 05:49 PM
benter905's Avatar
Cool
My 2006 HHR I have a little over 82,000 with the same battery and with no problems yet! By the sounds of it I better think about replacing it soon.
Old Jan 22, 2011 | 06:19 PM
urbexHHR's Avatar
My '06 with 50k may be needing one when I get it out from storage. Not really wanting to hold a charge this year...
Old Jan 23, 2011 | 12:16 AM
The worst sulfated battery can be created by just leaving a battery unattended for a long period of time. A battery is like a bucket with a tiny hole. Electricity leaks little by little through what is called "natural discharge". It may take some time to drain a battery completely (depending on vehicle), and sulfation created in this process is quite possibly the worst kind.
The Battery Tender is a battery's' best defense to a much longer life.
Old Jan 23, 2011 | 11:04 AM
Old Lar's Avatar
My '06 has 76+K miles still on the original battery. I keep thinking that it will need replacing sometime. After five years (March '06 purchased), I'm not sure how long batteries last in Florida.
Old Jan 23, 2011 | 11:08 AM
Charlie D's Avatar
The battery on my 06 went out around 58,000 but I also let the car sit for up to 4 or 5 months at a time during the spring thru fall when the bike is my transportation.
