Blend door knocking
Old Apr 7, 2020 | 01:18 PM
Bonez's Avatar
Blend door knocking
Ok Question.... The blend door actuator is super close to the side of the dash bracket, like 1/8" gap , unlike in the video, but that is my issue, the blend door slaps making that loud knock for a few seconds. There is no way possible to access the screws to remove it so, has anyone ever done this fix? is it possible to drop that whole side of the box without disconnecting ac/heat lines or removing the whole dash?
Old Apr 7, 2020 | 01:35 PM
Bonez's Avatar
Blend door knocking
Blend door actuator knocking, Has anyone replaced theirs and how?
I got behind the glove box and there is no room to get any tools in there (1/8") between the part and dash bracket (side of dash)
was wondering if theres a way to get to it to replace myself or if it can be dropped without disconnecting ac/heat lines? or is this a dealer repair? The blend door slaps creating a super loud knocking for a few seconds at start up.
This is from youtube, same issue but no access to get to the part
Old Apr 7, 2020 | 01:42 PM
Cat Man HHR's Avatar
Does the blend door work correctly?
If so, as it has been said, "If it works, don't mess with it".
From your description, it looks like a lot of work to make it factory.
Old Apr 7, 2020 | 01:48 PM
Hint
Don't double post.
You already have this question post in another section of the forum.
Old Apr 7, 2020 | 02:26 PM
Bonez's Avatar
Originally Posted by Cat Man HHR
Hint
Don't double post.
I know its mixed in my newb post, but thought this would get more techie hits for those who don't read other threads, not technically a double post, just more up front for the issue.
Old Apr 7, 2020 | 02:33 PM
Bonez's Avatar
yes, when its closed to pull outside air it "knocks" several time on start up, I also read it can cause battery drain when the car is off, then when you select recirculating, the door pulls to the front closing off the outside vent. So it works, I watched it as I selected the settings. on the vent setting it closes off inside and for about 20 knocks it just gaps about 1/8" and slams closed, I pushed on the actual door and its pretty tough when doing it ( I was gentle as I didn't want to break anything ) Im really surprised it can actually be that loud for barely moving. Im almost thinking to just unplug it if it will stay in the recirculating position. BUT Id rather have it fixed than rigged.
Old Apr 7, 2020 | 03:24 PM
Yea, let’s keep this over here. Less confusing, in the didn’t I just see that category?
search blend door actuator, and a lot of information will come up.
https://www.google.ca/search?q=hhr+b...&bih=626&dpr=2
Old Apr 7, 2020 | 04:04 PM
I believe the dash needs to come apart for replacement of that actuator... Not an easy job
Old Apr 7, 2020 | 04:38 PM
Bonez's Avatar
Yes, That's what I am coming to realize, since they built the car around it unfortunately...lol
Think one of these got in there....
Old Apr 7, 2020 | 04:50 PM
There are 3 actuators, which one are you having trouble with?
