Brake fluid/Clutch fluid flush??
Old Jul 19, 2012 | 07:39 AM
Tominator's Avatar
Originally Posted by sleeper
Auto Parts (here) have these also.. sort of a "Litmus Test strip"
Unless that shows contaminants there is no need to flush the fluid.
There are several brands of synthetic DOT3 fluids and as long as it meets GM specs it's OK to use.
Old Jul 19, 2012 | 10:08 AM
Sounds interesting - keep us posted on how it works out for you. Manually changing fluid has to be one of the most boring maintenance jobs - having the flush machine handy would be a treat. :-)
Old Aug 4, 2012 | 03:24 PM
frdfandc's Avatar
You can use DOT 3, DOT 4 and DOT 5.1. Difference is in boiling and wet points.
DOT 5 is synthetic and will truly F up your brake/clutch system since it wasn't designed for it.
I'll be doing mine soon with DOT 5.1.
Old Dec 19, 2014 | 06:23 PM
jmm121783's Avatar
Also no one mentions but if you have a manual and want to do a complete flush you will typically need about 2qts of brake fluid. THIS IS MANUAL ONLY THOUGH since brake fluid is shared with/for the clutch
MWG2
Maintenance and Upkeep
15
Oct 26, 2017 09:22 AM
redmom605
Drivetrain (Excluding Engine)
Aug 4, 2014 06:55 AM
Herbie
66
Jul 7, 2014 10:52 AM
bad03xtreme
Jan 23, 2011 12:52 AM
