SS 5 speed clutch fluid??
I have noticed my clutch doesn't have the same resistance as it had before. Where can I check the clutch fluid, is the brake fluid also used as the clutch fluid?
https://www.chevyhhr.net/forums/show...t=33399&page=4Post # 16
I know you built one bad Panel, but this is your post FWIW ^
