Brake Pedal Travel
Old 02-21-2017, 06:54 AM
aradmahogany's Avatar
Brake Pedal Travel
How much travel is considered "normal" for our HHR's? In other words when braking and at a stop, where is the pedal positioned where the car can move. Just wanted to see what the general consensus was on this topic.
aradmahogany is offline
Old 02-21-2017, 07:09 AM
Not exactly sure what you're asking here. Are you asking at what point an automatic trans HHR (in gear) will start to move when releasing the brakes ?
firemangeorge is online now
Old 02-21-2017, 08:24 AM
When the brake pads are new and the rear drums are adjusted correctly, the brake pedal is a little higher then when the pads are worn and the rear drums need adjustments
Oldblue is offline
Old 02-21-2017, 08:41 AM
I am saying when you depress the brake pedal where does it stop. How low?
Old 02-21-2017, 08:43 AM
Approximately 1 1/2 to 2 inches off the carpet, in mine!
Oldblue is offline
Old 02-21-2017, 10:08 AM
When a deer jumps out in front of you, it goes through the floor boards...
Greybeard999 is offline
Old 02-21-2017, 11:10 AM
Okay Oldblue thats about where mine is. Just seemed low to me is all! But now I am worry free! And greybeard LOL
Old 02-22-2017, 12:38 PM
spacer's Avatar
Mine got a little low after a panic stop (old lady in a Mercedes crossover decided she wanted to occupy my space), feeling really soft and going to the floor. Evidently, had something to do with the ABS. On some advice I found... somewhere... I took Herman to a wet, gravelly hill in my neighborhood where there was no traffic, and made a few ABS activating stops on the way down. Seems to have adjusted itself back to normal.
Still need to change out the rotors and pads, though. Those are just getting worn after nearly 170k miles.
spacer is offline
Old 02-22-2017, 01:17 PM
Spacer consider upgrading to larger diameter SS non Brembo front discs, here a great how to!
https://www.chevyhhr.net/forums/brak...ard-hhr-42938/
Oldblue is offline
Old 02-22-2017, 01:47 PM
spacer's Avatar
I'll have a look. Thanks!
spacer is offline
Quick Reply: Brake Pedal Travel
