brake question
Old May 20, 2018 | 12:31 PM
The bolt goes through the caliper and screws into the end of the pin which is in hole in the bracket. The slider is #1 in the pic.
You description of the damage is unclear.
Old May 20, 2018 | 06:11 PM
87z16's Avatar
well i got it out today.
last time that i did brakes in this, i used anti-seize on the slide pins. i guess that was what i did wrong. this is the pin that has a grommet on it, and was keeping the brake compressed due to the anti-seize solidifying. i got the slide pin out and the grommet out of the bracket. well im gonna clean them up and use the 'proper' grease this time.
THANK YOU FOR ALL THE INPUT!!!!!!
Old Jun 8, 2018 | 10:34 AM
desertrat's Avatar
Always replace the stainless brackets that help hold the pads in. They should also be lubricated with Never Seize, as well as the back of the pads where the piston or caliper makes contact. Use as little as possible, and don't get any on the pads or rotor. The pins shown in the photo by donbrew need to be cleaned and lubricated also, or the pad may not release and wear out.
Old Jun 8, 2018 | 01:13 PM
There is brake grease made for the purpose.
My personal experience with adding either glue or lube on the back of the pads is it doesn't make a bit of difference, as long as the shims are installed correctly. All of those "back of the pad" preps are supposed to be anti-squeal; I have never had squealing. I have even experimented with tossing the shims out with no squeal.
Old Jun 8, 2018 | 07:44 PM
Do Not use never seize on the brake pad lube points, it can’t handle the heat!
Use a silicone grease brake line designed for the specific application
Rjj
Oct 22, 2017 08:56 AM
Necrocajun
Aug 31, 2017 09:59 AM
bookdoug
11
Oct 3, 2016 07:24 AM
BirdSong
Apr 30, 2016 11:09 AM
Doctuh
Oct 27, 2010 03:29 AM
