change oil soon message
Old May 26, 2012 | 08:53 PM
alivelystone's Avatar
Thanks for telling me that - I've driven mine for over 50,000 miles and never knew how to reset it and neither did my friends --
Old May 27, 2012 | 01:13 AM
If ya have an owners manual, it is clearly explained in it..
I think there are online owners manuals here also..
Old May 27, 2012 | 08:10 AM
If you need a copy of your owner's manual alivelystone, just click the link below and then click your model year, a PDF version of your year's manual will then open. You can save it to your computer for future reference.
https://www.chevyhhr.net/forums/general-hhr-4/online-owners-manual-3074/
Old May 27, 2012 | 10:09 AM
Time before last I used the "gas pedal 3 times" method. This time around I turned on the key (engine not started) Held down the "INFO" and "enter" button for 3 seconds and "Reset oil life?" popped up in the display. I hit "enter" again and and it was reset. ("enter" = <--' looking thing ) Not sure why I didn't have to scroll through other choices in the preference menu to get to oil reset like I have in the past... (The Wizard probably knew I had just changed it's oil )
Different years had different methods but were similar. Check the manual or pump the pedal as was said above.
Old May 27, 2012 | 01:04 PM
If the "CHANGE OIL SOON" is lit up the DIC goes to oil life reset automatically when you push info & enter at the same time. It is the Goonies that know.
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
Budster
Oct 4, 2012 07:11 PM
kornellred
Nov 11, 2007 06:57 PM
Sep 1, 2007 12:42 AM
