Checking and replacing the air filter
Old Dec 14, 2012 | 07:33 PM
  #121
songman1505's Avatar
Originally Posted by IgottaWoody
Now change out that wolly worm restrictor tube you have and it wil be even better.....
Wonder if a clothes dryer vent tube would work?
Old Dec 14, 2012 | 09:52 PM
  #122
alexrckid's Avatar
wow.....new, that duct hose aint cheap......
http://www.gmpartseast.com/Page_Prod...Code=HR1&Year=
Old Dec 14, 2012 | 10:05 PM
  #123
7 **865168 DUCT FRT INT AIR 1 06 $49.77
I think you could go to a salvage yard & score one 'cheep'..
Old Dec 15, 2012 | 01:25 PM
  #124
alexrckid's Avatar
absolutely
Old Dec 15, 2012 | 01:27 PM
  #125
alexrckid's Avatar
49.77 for a piece of hose........must be lined with gold...
Old Dec 15, 2012 | 10:40 PM
  #126
I Wrapped mine with "flex Duct" tape, The silver kind made for flexible HVAC ducts, not Duck Tape. The old 2008 needed it after an engine cleaning, the 2011 got it preemptively.
I just checked the filter on my newish 2011 HHR, the front passenger side is BOLTED down with an Allen head bolt! You can only get 1/8 of a turn and the sharp edges of the housing played havoc with the back of my hand. The bolt is no longer there. The housing now has Duck Tape on the sharp edges, so I can remove the pressure cap bloodlessly.
The local Chevy dealer wanted $5 each for the nuts that hold the exhaust pipe to the cat pipe. Talk about gold hardware! NAPA was 2 for $.92 including tax.
Old Jan 8, 2013 | 06:35 PM
  #127
The Kirby guy's Avatar
Really?!
This air box is such pita to get off, I couldn't get the passenger side front attachment off the grommet, so had to remove the bracket from the block itself, and of course couldn't find my ratchet until after I had removed it with an adjustable wrench. Oh well, I'd say the toughest part was figuring the darn thing out. Once you know what to do, it's fairly easy. Look for a black bracket attached to the block with 13 mm bolts, then you have to worm it through the wiring. I did the air filter on my girlfriend's pt loser yesterday, and it took a total of three minutes. I guess that's what we get for owning an American car made in Mexico with a German engine. Lol
Old Jan 8, 2013 | 10:37 PM
  #128
Kirby guy-
Next time add a little hi-temp grease to the grommets & the cover will come off very easily...
It is over-engineered, but easy once ya do it..
Old Jan 31, 2013 | 07:24 PM
  #129
cameraguy1's Avatar
THANK YOU FOR THE INFO.
we are new owners of a 2011 LT and so far really like it. I will check the filter element out. Only 35,000 miles so probably not needed to replace will find out.
Old Jan 31, 2013 | 08:48 PM
  #130
If you go to the trouble to check it, save yourself the hassle and just replace it while you're in there.
