Checking and replacing the air filter
Old Jul 4, 2013 | 11:02 PM
  #141
Originally Posted by tkd83
Hi, I'm fairly new to the group and just wanted to say hello. I replaced the stock paper filter with a K & N the first year after I bought the car and boy I wish I had seen the post by Black Rose first. It was a major pain to replace... Seems like car manufacturers just try to make what should be an easy repair/replacement, harder.
1st time is hardest.. And if you wipe the rubber grommets with a dab of hi-temp grease, next time will be super easy.
Old Jul 26, 2013 | 12:42 PM
  #142
BaltoBob's Avatar
Thanks! It took me longer to find my Torx screw driver (left over from when I had a 84 Caddy, 20 years ago) then it took to change the filter.
Old Jul 26, 2013 | 01:30 PM
  #143
In case anyone needs to replace the grommets/insulators, here is a quote from Waldo posted just the other day:
"I just did the solenoid replacement, and also had the front grommet fall apart on me. GM calls this part an "Insulator". It's part #12563914, and it's current list is $3.47."
Old Dec 8, 2013 | 12:48 AM
  #144
sbrice54's Avatar
maf sensor question
I'm gonna try the same thing lunchbox did with the air cleaner assembly. My question is does the maf sensor need to go all the way across the intake pipe and is the distance of the maf sensor from the throttle body cruicial?
Old Dec 8, 2013 | 09:46 AM
  #145
It does not go all the way across on the OE.
I don't think distance is critical, it just needs to be in the air flow before the butterfly.
Orientation is critical.
Old Dec 11, 2013 | 05:50 PM
  #146
sbrice54's Avatar
maf sensor question
Okay, thanks donbrew. I may start a new thread if this thing flies...
Old Dec 14, 2013 | 04:25 PM
  #147
Dammit! I forgot to plug the MAF in AGAIN.
Old Jan 30, 2014 | 04:38 PM
  #148
Stevethefolkie's Avatar
what's with the whining? Took me 10 minutes to remove the housing, undo the bolts replace the filter and re-install the whole mess - if those who indicated hours are serious perhaps they shouldn't work on their own cars ...
Old Jan 30, 2014 | 04:48 PM
  #149
Snoopy's Avatar
Agreed
Old Feb 12, 2014 | 11:42 PM
  #150
LVJJJ's Avatar
so how often should the air filter be replaced? I'm in a no dust, damp and rainy climate. The manual says 50,000 miles, but that seems like too long a time.
