Checking and replacing the air filter
You ask the question, state the published answer, then challenge it yourself. There has got to be some latin phrase for that construction of debate.
Not complaining, just saying.
I had to go out to the shop and make the "mechanic" at the tire store stop destroying my car. He was really getting aggressive to do the "required" check, he was really upset when I told him I had changed it the day before.
I have to do it 2 - 3 times a year ( too much dust on local roads ) .
This damn "black box" makes me sad . Disassemble to make sure that the filter is dead. Then reverse assembly - to ride for a while , until the filter come to me through the post. Next new disassembly / assembly to install a new filter. Whole saga !
GM is trying to complicate this task to the limit. 7 bolts , each with a six "star" instead of the usual cross for screwdriver . I had to buy a special device .
In addition, detach this black coffin to get to these bolts . Hands in the dust , in the remnants of oil. Br -r-r !
Every time I carry this stuff in the home , my wife hysterical.
I was thinking about how to get one of those gizmos with filter of zero resistance . But they unjustifiably expensive .
i just got my 08 hhr not to long ago so i checked the air filter. mine was like new and it did not take me long to do, the bolt that goes on the pass side valve cover looks to me like it should have a rubber bushing. is there a rubber bushing there? mine has a washer that has a cup built into it but no bushing, thx for any help
It is actually a rubber grommet exactly the same as the other 2 on the back side.
Unless it makes noise you can't live with or a hole don't worry about it.
And, welcome!
