Checking and replacing the air filter
Old Feb 13, 2014 | 12:21 PM
  #151
Originally Posted by LVJJJ
so how often should the air filter be replaced? I'm in a no dust, damp and rainy climate. The manual says 50,000 miles, but that seems like too long a time.
Then change it when you think you should, there is no lower limit. The manual is mainly economics. "ECOTech"
You ask the question, state the published answer, then challenge it yourself. There has got to be some latin phrase for that construction of debate.
Old Feb 13, 2014 | 03:50 PM
  #152
The phrase you're looking for Don is "res ipsa loquitur"- "the thing speaks for itself", or more loosely translated, "the question speaks for itself".
Old Feb 14, 2014 | 08:00 AM
  #153
I knew a lawyer would have one!
Old Mar 11, 2014 | 11:34 AM
  #154
mikelikestobike's Avatar
Originally Posted by Stevethefolkie
what's with the whining? Took me 10 minutes to remove the housing, undo the bolts replace the filter and re-install the whole mess - if those who indicated hours are serious perhaps they shouldn't work on their own cars ...
I agree with the above. But access to the filter in the HHR is overly complicated. I've had other cars where it was open hood, undo 3 or 4 clips and you had access to the filter. 5 seconds, no tools...
Not complaining, just saying.
Old Mar 11, 2014 | 01:54 PM
  #155
I had to go out to the shop and make the "mechanic" at the tire store stop destroying my car. He was really getting aggressive to do the "required" check, he was really upset when I told him I had changed it the day before.
Old May 5, 2014 | 03:35 AM
  #156
geg's Avatar
geg
x2
I have to do it 2 - 3 times a year ( too much dust on local roads ) .
This damn "black box" makes me sad . Disassemble to make sure that the filter is dead. Then reverse assembly - to ride for a while , until the filter come to me through the post. Next new disassembly / assembly to install a new filter. Whole saga !
GM is trying to complicate this task to the limit. 7 bolts , each with a six "star" instead of the usual cross for screwdriver . I had to buy a special device .
In addition, detach this black coffin to get to these bolts . Hands in the dust , in the remnants of oil. Br -r-r !
Every time I carry this stuff in the home , my wife hysterical.
I was thinking about how to get one of those gizmos with filter of zero resistance . But they unjustifiably expensive .
Old Jun 15, 2014 | 03:42 PM
  #157
jay loukakis's Avatar
That's why the dealers get RICH Chevy designed it that way??????????????????????
Old Mar 27, 2015 | 08:05 PM
  #158
mtrhead79's Avatar
i just got my 08 hhr not to long ago so i checked the air filter. mine was like new and it did not take me long to do, the bolt that goes on the pass side valve cover looks to me like it should have a rubber bushing. is there a rubber bushing there? mine has a washer that has a cup built into it but no bushing, thx for any help
Old Mar 27, 2015 | 09:27 PM
  #159
Yes, but they usually disappear, usually due to frustrated owners like me.
It is actually a rubber grommet exactly the same as the other 2 on the back side.
Unless it makes noise you can't live with or a hole don't worry about it.
And, welcome!
Old Mar 30, 2015 | 08:24 PM
  #160
mtrhead79's Avatar
cool
