Confirmation for O2 Sensor Part Number
Old Aug 31, 2018 | 08:45 AM
thex's Avatar
Hey guys. I need you help to confirm the part number for a 2009 LT 2.2L #2 O2 sensor (after the cat.)
Looking thru the information on this great forum, I believe I need ACDelco 213-3138.
When I visit RockAuto or Amazon, they both say this is the incorrect part for my car.
Also, if you can also identify the part number for the #1 O2 sensor - might as well do both on the 160K mile car!
I appreciate any assistance you guys can give!
Thanks!
Old Aug 31, 2018 | 10:11 AM
Cat Man HHR's Avatar
Rockauto shows both up and downstream sensors. Up is #1 and down is #2.
https://www.rockauto.com/en/catalog/...2)+sensor,5132
Old Aug 31, 2018 | 10:17 AM
GM12611127 #1 Which is ACDelco 213-4195
GM12578576 #2 Which is ACDelco 213-3138
Why would the #2 need replacing? If you have a code the most likely cause is a wire laying on the exhaust pipe. It only monitors the function of the Cat, The #1 does all the A/F work.
If you are thinking P0420 means the sensor is bad, you are 180 degrees wrong; it means it is doing it's job.
Old Aug 31, 2018 | 10:53 AM
thex's Avatar
The code I am getting is P2270.
Old Aug 31, 2018 | 01:01 PM
Read the potential causes in this
https://www.obd-codes.com/p2270
Old Aug 31, 2018 | 01:12 PM
thex's Avatar
I really appreciate your help/expertise!
I read the following at the site;
"The most common fixes for this DTC seem to be either an exhaust air leak, a wiring problem with the sensor/wiring, or the sensor itself. If you replace the O2 sensor, buy an OEM one (manufacturer brand) for best results."
My plan was;
  1. inspect the wiring first - if it appears intact and not touching the exhaust, then
  2. Replace the O2 sensor.
  3. If the code still appears - then I would tackle the Flex/Cat exhaust.
Please let me know if I am misinterpreting the cause and/or if there is something else I should check before getting the O2 sensor.
Old Aug 31, 2018 | 01:28 PM
While you are inspecting things look at the flex pipe.
BTW; the sensors are NTK/NGK rebranded parts, you might save some money, I definitely would not shop at the GM parts department.
Old Aug 31, 2018 | 01:51 PM
thex's Avatar
Thanks Don!
Local dealer wants $143 for the sensor.
Amazon ACDelco is $46 and the NGK is $55.
I hope to get to this over the weekend. Also changing out the plugs (with ACDelco) and air filter this weekend.
hhr_2009
2.2L Performance Tech
Feb 3, 2011 10:55 AM
-md- HHR
12
Oct 29, 2007 08:42 AM
dbarberaz
May 22, 2007 07:17 PM
ssrodder
Mar 15, 2007 07:42 AM
