Creaking
Creaking
Just inftslled new LCAs now I have a horrible creaking noise sounds like the car is gonna tear apart we loosened all the bolts pushed it up and down tetightened them all never seeze the bushings sounds like it’s coming from the.horizonal bushing I don’t know what to do or look for it was quiet before just the noise from the rear bushing can someone help
Both sides?
do you have an SS?
when does it creak?
You could try squirting WD40 on 1 spot at a time to narrow it down.
look at the isolators on the springs.
look at the sway bar bushings and end links.
do you have an SS?
when does it creak?
All new? complete Struts (shock,spring,mount), sway bar bushings, sway bar end links, LCA. Nothing else moves
Check the 3 nuts on the top strut mountings.
Important questions: is it an SS? Under what conditions does it creak?
