Timing chain
Old Apr 27, 2019 | 07:23 PM
Cliffs51's Avatar
Timing chain
Im doing the timing chain on my 06 2.4 next week. I realized today that the transmission is in park. I will need to rotate the engine to bring the no. 1 piston to top dead center. Will I be able to shift the auto trans into neutral with the battery disconnected or am i going to have the battery connected?
Old Apr 27, 2019 | 07:28 PM
What do you do while warming the car up in your driveway?
Torque converter? Not clutch.
Old Apr 27, 2019 | 07:49 PM
You have to jack up the HHR to change the timing chain, you can shift into neutral, or just turn the crank clock wise.
Old Apr 27, 2019 | 08:28 PM
Cliffs51's Avatar
Yep. I know the procedure. I had put a towel over tge hatch latch when i disconnected the battery cable but it must have moved when i closed the hatch because the hatch is partially locked now. I was hoping i wouldnt have to crawl back there to hookup the battery. Oh well im still pretty limber at 67 😁 I can do it
Old Apr 27, 2019 | 09:16 PM
Hook up jumper cables under the hood , even a 9 volt battery plug in memory minder.
Old Apr 27, 2019 | 10:22 PM
hellshotrod's Avatar
just pop the cable end off the trans and shift it buy hand no need for power bam your done .....
Old Apr 27, 2019 | 10:27 PM
Why would you bother doing anything with an automatic? The torque converter decouples or you couldn't start the car in park.
Old Apr 27, 2019 | 10:35 PM
the tc has nothing too do with starting the car in park thats the netraul safety switch , job he ask how to put in N and the shifter lock out switch he was having probs with
Old Apr 27, 2019 | 11:34 PM
fastsuv's Avatar
The OP was asking how to shift the car into neutral so he can rotate the engine to TDC on plug 1.
Don correctly stated that the engine can be rotated all you want with the trans in park. No need to do any shifting, the TC will let the engine freewheel.
Steve
Banana hands
Apr 17, 2014 04:49 PM
dnutbrown
Aug 13, 2012 10:48 AM
TEKNOnaut
Jul 13, 2012 06:56 AM
codered3232
22
Mar 6, 2012 09:01 AM
wagoneer
Apr 9, 2009 11:44 PM
