cylinder number
Old Dec 15, 2013 | 01:30 PM
canroc's Avatar
cylinder number
I have a P303 code indicating a misfire on cylinder 3. Coincidently I recently changed the spark plugs, so I will check out the one in cylinder 3. However I don't know which cylinder is number 3. Anyone know? Thanks.
Old Dec 15, 2013 | 01:57 PM
No.1 cylinder is the front of the engine, which would be the passenger side of the car. The rest just go in order: 1,2,3,4.
Old Dec 15, 2013 | 03:41 PM
Lucky's Avatar
X2 and you can swap plugs and coils into different cyl. To see if the misfire moves for help in diagnostics.
Old Dec 15, 2013 | 07:06 PM
canroc's Avatar
Thanks.
Old Dec 17, 2013 | 04:17 PM
malibuhhr's Avatar
If you recently changed your plugs then your mileage is probably getting up around the point where Ecotec's throw the misfire code...there are a lot of threads on the subject and it often indicates you have a burnt valve (in this case in Cyl 3) which requires the cylinder head to be removed, valve job and new valve or valves in Cyl 3, costing $1000-1500 depending on what parts you change.
The ONLY way to check for a burnt valve is a simple compression check. You can buy a compression guage cheaper than garages will charge you for the test. I got 180 psi in 3 cylinders and 90 psi in the one with the burnt valve. Drove with CEL on for 30,000kms, then the idle got rough, then I checked compression and finally had to bite the bullet and take it to the machine shop...now it runs perfect!
dzmija
Oct 27, 2013 04:34 PM
donbrew
Jan 22, 2012 05:32 PM
10RedSS
Jan 13, 2012 07:10 AM
kjarels
Nov 10, 2009 03:09 PM
c2vette
Feb 11, 2009 12:35 PM
