dash lights too dim
Old Jun 18, 2013 | 10:21 PM
ppaul's Avatar
dash lights too dim
when I turn the auto headlights off the radio and the DIC lights brighten quite a bit, but the dash lights are very dim if on at all, the speedometer and the dash land almost impossible to see in daylight because of the shadows. there is a small bump on the dash by the front glass, does this control the dash lights? and can I brighten them with out alot of work? thanks
Old Jun 19, 2013 | 12:36 AM
"there is a small bump on the dash by the front glass, does this control the dash lights?"
No, that is the eye that turns the head lights on or off according to outside lighting conditions..
Have you turned the pinwheel on the dash ?
Old Jun 19, 2013 | 04:41 AM
The bump/dome is the ambient light sensor, that controls the activation of the "Auto Lights" function in low light situations. When you select "Off" you are also turning off the dash lights which causes the DIC and radio displays to default to full brightness.
If you wish to keep the dash lights on, use the automatic function, or turn the headlights on manually. If you have the dimmer control on the dash turned all the way to the right, that's all the brightness you will get.
The dash lights also illuminate when you manually turn on the parking lights, but it is illegal in most states to drive with only the parking lamps illuminated.
Old Jun 19, 2013 | 12:10 PM
cameraguy1's Avatar
Red face dim dash lights
We too have the same problem as when it is bright outside it is almost impossible to see the speedo,or gauges. The DIC is always bright? Night time, all is OK. Even with the lights on manual on it is impossible to see the stuff in the daytime.
Old Jun 19, 2013 | 12:20 PM
And I thought my cataracts were bad!
Old Jun 19, 2013 | 10:44 PM
Say what ? What about older hhrs, their DRL is the parking lights (ONLY)..
Not to mention older cars in general.
Old Jun 20, 2013 | 12:36 AM
Dem aren't parking lights, they be posing lights.
Old Jun 20, 2013 | 10:56 PM
Dats true.. & certainly NOT illegal for driving..
Old Jun 21, 2013 | 09:29 PM
My mother got a ticket in S.C. in 1963 for driving with her parking lights on in the rain. The cop said "they are called PARKING lights not DRIVING lights".
Just sayin'.
Old Jun 23, 2013 | 05:04 AM
PrairieHHR's Avatar
Just to make sure, are you aware of the slider on the dash that controls the brightness level of the dash (radio and gauges)? If not, it is located within the red circle:
I know some people don't really notice that button all too often as it isn't of great importance. I rarely touch the thing.
