Don't think it's just a stone chip!
Old Oct 26, 2018 | 04:45 AM
Cat Man HHR's Avatar
X2 ^^^^^
Old Oct 26, 2018 | 01:35 PM
X3, I insisted to cut out the rust, it never sleeps!!
Old Oct 27, 2018 | 09:48 PM
Ain't dat the truth, Very nice job on yours Blue.
And the paint blend is spot on.
Old Nov 1, 2018 | 04:32 PM
hurst2001's Avatar
Originally Posted by sleeper
Welcome back hurst2001- Not oldblue (obviously) , but I'll throw in my .02 fwiw, if you plan on keeping the ride, do it right & replace the bad metal. You will be much happier.
Grinding down the rust & glassing it in is only a temp fix, the problem will re-appear in the future.
ok went to a body shop and they want to replace the rear quarter panels both have the problem at about six grand are you nuts !! It has the typical rust bubbles which I know will come thur .. so why can’t you patch panel ? I mean as soon as you cut it out you may be able to to use Por 15 inside the panel we’re it will stop the rust .. I know it will come back but that’s probably years .. I mean I got a 2007 lt2 with 112000 that runs great but I like to get this fix for a decent price .. it’s just a shame how they rust like that ... just asking for advice thanks
Old Nov 1, 2018 | 08:57 PM
JimDaddyo's Avatar
Mine had rust bubbles in the same spot. I sanded it down and the metal was still good. Hit it with some etching primer, sandable primer then the colour. The colour doesn't match worth a damn. I've never had luck getting any touch up paint to match. The only place I can get it is at the local NAPA but it's always been too dark. I told the guy to lighten it a bit and now it's too light...lol. Still looks better than a rust bubble though.
Old Nov 5, 2018 | 07:02 AM
Ohiocruiser's Avatar
From the years of dealing with rust, I learned one thing. Once it starts it always wins. I use a lot of fluid film, especially in the winter time, to prevent it from starting. That makes it very,very messy to work underneath. But I'd rather deal with dirt and grease, than rust.
Old Nov 5, 2018 | 07:58 AM
X2^^^^^^^, you can wash off the fluid film, not the rust!!
I fixed a rust spot on the liftgate four years ago in a similar procedure, I spot sand blasted the rust , then Eastwood’s rust converter then primer then Duplicolor colour and then clear coat, the is back !! Already!
Old Jan 11, 2020 | 05:01 AM
hursst's Avatar
Panel Rust Repair
Hello,
Great job on this repair! Where did you get the patch panel for this repair, or did you make it yourself? I have the exact same problem, but only on one side, Thanks to the Virginia DOT salt brine they put down for no reason. 2007 HHR 1LT, 243,000 miles and counting...
Old Jan 11, 2020 | 10:32 AM
Hand made patch panel by Len my new body guy, since Gino my previous guy retired. And now that Len has retired .?
Old Jan 11, 2020 | 11:05 AM
Originally Posted by hursst
Hello,
Think Arizona car.
If someone from out that area can cut you out that piece your good to go.
Or find a quarter in your area that might(?) be good.
