Dropping the headliner: coat hook?
Old Feb 15, 2014 | 03:09 PM
paulBvtn's Avatar
Any tips on removing the coat hooks from the headliner?
I can't figure. It out!
P
Old Feb 15, 2014 | 03:35 PM
screw under the hook after you pull the tab under the hook down.
That doesn't make it clear, but there is a removable cover under the hook part
Old Feb 15, 2014 | 09:01 PM
paulBvtn's Avatar
Thanks donbrew, is the tab at the top behind the hook, or at the bottom?
I can't figure out how to get a trim tool in there to pry anything out.
Thx
Old Feb 15, 2014 | 11:00 PM
IIRC, the "hinge" is down by the hook hinge. Just stick something in the gap and pry.
It is a filler piece inside the hook assembly to cover the screw hole (1) in the drawing.
Once you do it you will be I was.
Old Feb 16, 2014 | 12:53 PM
paulBvtn's Avatar
Got it. A bright light showed the screw behind the top half behin the hook. A quick pry with a screwdriver and I'm in business.
I couldn't get the headliner out without pulling all the rear panels. Weeeee
Old Feb 16, 2014 | 03:16 PM
paulBvtn's Avatar
I must be crazy:
Almost all taken apart (only doin the back) and one day left.
Old Feb 16, 2014 | 03:28 PM
Why are you doing it? I had to do mine because I had to replace the side curtain airbags.
When you put it back together be careful of the leading edges of the airbags under the A pillar cover.
Old Feb 16, 2014 | 03:29 PM
You getting ready to dynamat that puppy ? Are you reskinning if black ?
still have 18 questions left but figured you were busy
Old Feb 16, 2014 | 04:09 PM
paulBvtn's Avatar
Ha yes, sound deadening.
tireman1554
Mar 30, 2010 12:08 AM
Czechman
Apr 4, 2009 08:54 PM
ColeTrickle
2.0L Performance Tech
41
Aug 1, 2008 07:16 PM
Goose
Nov 12, 2007 06:35 AM
GhstRider
Sep 11, 2006 07:37 AM
