Engine oil bolt hard to get off!
Old Sep 21, 2010 | 03:19 PM
urbexHHR's Avatar
May I ask where you got this oil change done at... I don't usually take stuff in for oil changes, but I'll make sure to avoid them...
Old Sep 21, 2010 | 06:04 PM
The jack stand points I use are right on the bright bolts that hold the lower suspension member onto the frame. When you jack it up and look under there they stand out.
I can't make mine go up ramps without installing stops on my garage floor! But, oil change does not "require" elevating, if I would lose a few pounds. literally ROF-L!
Old Sep 21, 2010 | 06:17 PM
ChevyMgr's Avatar
Try this link for lifting:
https://www.chevyhhr.net/forums/show...t=14470&POST#8
Old Sep 21, 2010 | 10:55 PM
Mowgli's Avatar
Originally Posted by carajean
Anyone ever heard of a puralator oil filter? Thats all they had at auto zone. Didnt have any ac delco.
I use NAPA Gold - they're the same as Wix = very good
urbexHHR's Avatar
I just buy AC Delco from the parts dept. at the dealer.
Old Sep 22, 2010 | 12:57 AM
I get my AC Delco filters at the auto parts @ $4.99 w/ O-rings..
Don't forget a magnetic drain plug..
PS: I wrap one wrap of teflon tape on the drain plug threads, always easy off..
Old Sep 22, 2010 | 01:02 PM
carajean's Avatar
Got it done at the fast eddies on miller road near GV mall.
Old Sep 22, 2010 | 01:04 PM
urbexHHR's Avatar
Ah, ok. I was hoping it wasn't Patsy Lou... Just got a coupon for a $9 oil change there and gave it to my friend, who I usually change the oil for anyways... I don't want to have her get it done there so that I can't get the bolt back off on her Saturn! When they did it at RPM when she bought the car it was on so tight I don't know how they didn't bend the oil pan or anything...
Old Sep 22, 2010 | 04:28 PM
09 Silver Bullett's Avatar
Yeah they prolly did. I hope its not cross threaded better not be. Im gonna have my BF come and bust it loose for me.
Also has anyone ever found a good placement for jack stands on this car? Cant go near the edge anywhere.
Purolator has been around for a very long time, safe to use I would say.
Old Sep 22, 2010 | 05:11 PM
knelson1969's Avatar
Hi there use a 6 point box end wrench or socket and make sure the head is completly clean and not allready worn out on the outer edges if the bolt head is good and you are using the correct size 6 point wrench or socket with one hand holding the tool firmly
on the head and with the other hand use allyour body weight like a impact to jar the bolt
loose if you try to use constant pressure the bolt may not comeout. some times you can gently tap the wrench with a hammer slightly and break it loose. make sure you replace
the oil drain plug sealing washer or o-ring lube with some old oil and the plug should seal good and come out easy next time.
