first HHR oil change
Old Aug 13, 2010 | 08:10 AM
BirdBrain's Avatar
Use royal purple...it is 12.00/L here in Canada but those of ya in the US can get it for less. High performance oil, gives you a bit more HP but more inportantly it runs the cleanest. I noticed a big difference when I changed it in my 09 HHR during its first oil change.
Old Aug 21, 2010 | 12:08 AM
Somewhere some members posted not being able to get a full 5 Quarts in on an oil & filter change..
I've done mine twice & get a full 5 qts in & reads perfectly full on the hot dipstick.
What I do is pull the fill cap, then go under & remove the drain plug, come up & remove the filter... Go do something else for about an hour. (yes about an hour) That really gets a good drain done.
Then install drain plug, oil filter & it takes the Full 5 quarts & not overfull..
Yes I do put a clean cloth over the fill tube & oil filter housing, so no dirt or whatever could enter while I'm doing something else..
IIRC, ChevyMgr may have stated that GM says 1/2 hour for thorough draining of heated oil..
solman98
Maintenance and Upkeep
255
Aug 8, 2014 07:39 AM
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
23
May 12, 2013 02:01 PM
SIHHR
Feb 14, 2007 07:35 PM
