GM air intake
Old Aug 3, 2010 | 08:09 AM
saltyfishguy's Avatar
GM air intake
Hey guys, been awhile, gotta question. How often and with what should I clean the filter on my intake, had it for awhile now.
Old Aug 3, 2010 | 09:06 AM
solman98's Avatar
Clean it when it looks dirty. Different roads will make all the differance in the world on how fast a filter gets dirty.
Old Aug 3, 2010 | 09:37 AM
That makes sense, what do I use to clean it with? Soap and water? Can you buy replacement filters still for these?
Old Aug 5, 2010 | 02:34 PM
mrarff's Avatar
Exclamation
Stock filter or aftermarket? Paper , foam, or cotton? If it's a paper filter, it goes in the garbage. If it's a foam or cotton mesh, clean it with a good detergent and rinse, rinse, RINSE! And if it is washable DO NOT spray anything on it! That is asking for a failed MAS. If you must do more to it, get a used pair of panty hose and make a "sock" for it. (same thing as a fancy pre-filter)
Old Aug 5, 2010 | 02:37 PM
mrarff's Avatar
Exclamation
Old Aug 5, 2010 | 05:15 PM
It's the gmpp intake, reusable. This thread got moved here, sorry for the 2x.
Old Aug 12, 2010 | 03:09 AM
mrarff's Avatar
Cleaning Filter
As I said, clean it (in the sink works) with a detergent, soaking is good also. Then rinse, rinse, and rinse again.(don't forget to let it dry in the sun, or blow it out good with an air hose. NEVER use a heat gun) When you put it back, DO NOT spray any light weight oil, silicon, or anything else on it. This can contaminate the MAS and those are not cheap!. I've got a K & N kit, and I cut a "sock" from the foot of a pair of my wife's discarded pantyhose. You would be suprised how much dirt this catches. So much that I only have to clean the filter about once a year! Just my two cents. Happy Motoring.
drummerboy0088
2.2L Performance Tech
19
Feb 10, 2015 12:25 PM
Michael20832
2.0L Performance Tech
Jul 8, 2009 05:16 PM
