Good luck with the taillight bulbs.
Fish goes blub. This is a bulb.
So you got into the cargo area, removed the access panel, rotated the bulb holder, removed the bulb/bulb holder assembly from the housing, then removed the bulb from the bulb holder. At some point the bulb broke, and you're not sure if you got all of the old bulb out of the bulb holder. Is all this correct so far?
So is the problem that
1. You cannot get the new bulb into the bulb holder? or
2. You cannot get the new bulb/bulb holder assembly into the housing?
Here is a link that is in my sig.
https://www.chevyhhr.net/forums/how-...r-post-52643/?
The blub holder is fine. The blub is in it now. I jus can't push the blub into the housing the opening isn't wide enough.
Well, if we can figure out for sure what is wrong, you can
1. Order new
2. Buy used from an auto parts recycler(wrecking yard or pull-a-part)
3. Buy used from a classified ad like this one https://www.chevyhhr.net/forums/clas...hhr-1lt-55831/
So see if you can get that pic uploaded and posted.
1. Order new
