Good luck with the taillight bulbs.
Old Aug 14, 2016 | 07:38 PM
  #41
Ashes25's Avatar
Originally Posted by donbrew
Is that because you are not lining the key up with the keyway (tab into slot).
The whole looks to small for the size bulb but it's the correct bulb
Old Aug 14, 2016 | 07:41 PM
  #42
If it came out easy enough, it should go back in.
Have you got a friend or family member that could give it a try ? If not, then a picture sure would help. Follow the link in Don's signature or just put the picture in your gallery(the little camera icon under your name).
We can extract the pic from your gallery.
Old Aug 14, 2016 | 07:46 PM
  #43
I think we are dealing with either a damaged housing where it is melted to the point where she cannot insert the bulb thru the opening - OR the bulb is the wrong one and will not fit thru the opening of the housing. Dare I ask what the number of the bulb is that you are trying to use?
If the last few suggestions/questions don't help you resolve your problem, I don't think we can help you much further. You might have to swing by a dealer and have them check it out.
DaytonaBlueMetallic
War Stories
May 7, 2014 08:32 AM
bobiroc
Jun 29, 2010 07:59 PM
HillsdaleHHR
Dec 10, 2009 09:55 PM
masterchief1112
Apr 3, 2009 11:50 AM
mizzouHHR
Mar 15, 2008 06:17 PM
