For guys that did transmission fluid change
Old Jul 23, 2013 | 07:49 AM
Hurst2001 , to answer your question I choose Mobil synthetic but Castrol, and Valvoline have similar fluids.
Old Jul 23, 2013 | 11:47 AM
Is there a filter to change?
Old Jul 23, 2013 | 01:20 PM
db/sb's Avatar
Yes, there is a filter.
Old Jul 23, 2013 | 03:22 PM
DexRon VI specification is a Synthetic.
Old Jul 26, 2013 | 05:57 PM
I just purchased a "transmission filter kit" from Advance for around $20. It's got a filter and a pan gasket.
My estimation of re using an after market gasket has changed, that thing is thin with no ribs or metal inner lining. I will probably re use the OE gasket.
I did re use the OE gasket. The 2011 had 2 donut magnets on the pan instead of the 1 square magnet on my 2008. I noticed a fair asmount of gray sludge in the pan, comments? The ATF was still "red-ish" after 96,000 miles, but closer to black.
I do notice a difference in shifting, but that may be because I put almost a quart more in than came out. I have added a ATF cooler since I got the car, and seems to have a small leak on the R side axle seal.
Old Jul 3, 2018 | 01:47 PM
hhrsskzoo5spd's Avatar
Where can I find instructions on changing transmission fluid in the 5-speed manual HHR 2.0L
Turbo?
Old Jul 3, 2018 | 03:11 PM
Turbo?
Why would you replace it?
Simply put: drain it, refill it.
Assuming you have the GETRAG , close to the same on MU3
drain the bottom hole. fill at the top hole. Big arrow toward front of CAR.
Old Jan 23, 2026 | 12:26 AM
DvaPatt's Avatar
Coming up on 180K miles, with unknown history, I guess I should change the trans fluid. There's a local shop with a special for $109.
Old Jan 23, 2026 | 06:52 AM
You can change it yourself, you get what you pay for!
Old Jan 23, 2026 | 08:05 AM
The correct fluid (Dexron VI) is going to cost around $40 a gallon, you need 7 quarts. If you have a shop do it be sure they use Dexron VI, that is full synthetic several different brands make it.
