HHR heater won’t turn down
Old Nov 22, 2024 | 09:07 AM
Corvairdan's Avatar
I have a 2008 HHR. If I start the car cold and don’t turn up the heat it stays off. If it turn it up, the heat comes on full blast and won’t turn down. Any ideas? Is it the heater control module?
Old Nov 22, 2024 | 09:13 AM
Most likely the heater resistor
Old Nov 22, 2024 | 09:28 AM
If you mean that the fan only runs on high it is the resistor
Old Nov 25, 2024 | 09:38 AM
desertrat's Avatar
If it is the original heater fan you have to cut it out with a razor knife. I'm not sure if the resistor is with the fan or behind another panel.
Old Nov 25, 2024 | 10:20 AM
When the resistor goes bad the default is high only, because the path goes directly to ground. The resistor is a separate module.
Old Nov 25, 2024 | 02:01 PM
The resistor is easy to change , and not very expensive
Jim's 2009
Mar 28, 2024 04:10 PM
RedRydr
Oct 8, 2021 08:13 AM
dougschwartz927
Maintenance and Upkeep
Aug 18, 2021 09:05 PM
eagle914
Jan 15, 2013 11:10 AM
cricketLT2
Nov 28, 2012 06:39 PM
