How to change your own oil.
Old Oct 14, 2009 | 12:30 AM
  #101
Originally Posted by Tannerman
I could not get a 32MM or a 1-1/4" socket that would fit because the manifold is in the way on my 2009 HHR LT2. I ended up purchasing the shortest 32MM socket I could get at Advanced Auto. I used a bench grinder to shorten it 3/8" and took off a crescent edge at the top. The socket ended up being 1-3/8" tall instead of 1-3/4". I took some pictures but do not know how to insert. Anyway, it works great.
On the 2.4 a regular socket just won't get it. I snagged a 32MM box wrench off eBay. It works fine too.
Pic posting FWIW: You can upload in the gallery. Then right click the properties & copy the URL and paste it in a post you want. Add [img]urlgoes here[/img] & that's it..
Old Oct 14, 2009 | 05:26 AM
  #102
solman98's Avatar
Wonder if Advance no longer sells the AmPro brand socket? That's the one I purchased and it fits perfect in the space.
Old Oct 14, 2009 | 07:52 AM
  #103
Ramos's Avatar
Originally Posted by diskullman
No one seemed to have a problem with the 32 mm socket? The picture at the beginning shows a nice 32 mm socket with a reduced head on the drive end. I couldn't get my standard Craftsman 32 MM ½" drive socket down on top of the cap without a couple hous of work with grinder. I had to shorten the socket, and cut down it's massive head. Is that a plastic intake manifold on my 2.4 L engine?
On my 09 HHR 2.2 the intake manifold partially restricts access to the filter cap. GM have their own tool, a crows-foot wrench but I purchased a low profile 32 mm 3/8" drive hex socket from a nation wide suplier here in Canada call "Complete Lube" who are also in the US. The tool was manufactured in China (where else) but is marketed out of Carlstadt NY by WWW.CTATOOLS.COM an interesting web-site to look at. Part number is 2572 called "RiteFit". Special for the Ecotecs. It was about $8.00, probably $6.00 in the States.
Old Oct 14, 2009 | 07:25 PM
  #104
unique_w's Avatar
Anyone interested in this QWIK VALVE, here is some info from them -
"Either F-107 or F107N can be installed with the HHR engine. You might need
adapter ADP-107 as well due to the recessed oil drain port."
http://www.qwikvalve.com/search.php?...10&modelid=243
Originally Posted by laborkei
Great Explanation, detail, and pictures.
I would like to suggest one of these oil plugs.
A quick flip of the lever, and the oil comes out.
No need to use a wrench or get your hands dirty.
http://www.quickoildrainvalve.com/
I have one on both my HHR and Colorado.
I don't suggest it to anyone who has replaced there springs and are running low to the ground.
Keith
Old Oct 15, 2009 | 12:09 AM
  #105
Yes socket costs $7.12
but shipping is $10 bucks..
Old Oct 15, 2009 | 05:32 PM
  #106
Tannerman's Avatar
2009 hhr
I have a 2009 HHR. They must of changed something to not allow the normal socket wrench to work.
Old Oct 15, 2009 | 05:37 PM
  #107
solman98's Avatar
Well you see mine in the pics, what's different on yours?
Old Oct 15, 2009 | 10:07 PM
  #108
solman-
I called Advance today, they still carry AmPro, but didn't have the 32mm in stock.
They also carry a line called something else (I forget ?) but says it made a special socket for our style oil filters & is a very shallow 32 mm socket, but it's listed for 2.2, so might not work ?
I have to swing by there over the weekend. I'll have to see, & try it under my hood while there..
Also here's a socket for our oil filter canisters on eBay
http://cgi.ebay.com/ebaymotors/SATUR...item53dd4527a2
Old Oct 16, 2009 | 03:28 PM
  #109
FlaHHROwner's Avatar
when draining the oil it's best to use the drain plug instead of using a foreign object in the road to puncture a hole in the pan. while the oil drains really fast this way, trying to reseal the hole is very difficult and costly. I speak from experience.
Old Oct 16, 2009 | 08:32 PM
  #110
XXL's Avatar
XXL
I have used this technique on the truck in my sig. Reseal was difficult. Check. And costly. Check.
