I replaced my coolant. Did I make it correctly?
Old Apr 5, 2012 | 11:15 PM
Zagohhr's Avatar
Originally Posted by bigjacksauto
fluid was cool in radiator when you drained it last?
how much of the 100 percent antifreezed did you ad?
what type antifreeze did you add?
did you or can you purchase locally a antifreeze tester to see what percentage anti freeze your system is after it has been run and cooled down a couple times?
1. Yes, was cool.
2. I mixed 50 percent of cooland and 50 percent with water.
3. Dex-cool prestone.
4. I purchased this just i case
Old Apr 5, 2012 | 11:54 PM
Zagohhr's Avatar
If the moderators allow it, this is the guide that I follow:
http://www.youtube.com/watch?v=TlNJDy_bZDE
What is diferent with the HHR?
Old Apr 6, 2012 | 08:12 AM
Sidecardog1's Avatar
According to my shop manual, the water pump drain plug is on the underside of the pump. However, I am looking at my 2010 shop manual for your style motor and I am assuming that your year is similar. I can't look at my engine since it is the 2.0L SS. You really should consider getting this done professionally. Looking to save a few bucks here can get very costly down the road. You need to get your coolant passages cleaned out quickly before damage occurs. I tried scanning the shop manual pages for you to attach, but I am unable to reduce the file size small enough for this site due to the very small limitations.
Old Apr 6, 2012 | 08:30 AM
Juan, if you can PM me with an e-mail address, I will gladly send you the cooling system section of the service manual in PDF form. These engines can be hard to work on in certain aspects, at the top of the list is the cooling system.
Old Apr 6, 2012 | 07:07 PM
atom's Avatar
http://www.bigmotors.by/forum/viewto...&t=83&start=50 )
Old Apr 6, 2012 | 07:36 PM
bigjacksauto's Avatar
the biggest problem I have with that video is that they only have you fill it with clean water I believe once.If you filled it with clean water heated up and drained and refilled about 5 times you would then have a clean clear system.
but it sounds like you only did it as the video showed and I am sure as others mentioned above you have a mix of old antifreeze new antifreeze and coolant flush
Old Apr 6, 2012 | 11:07 PM
Did you get the cooing system PDF I sent you Juan?
Old Apr 7, 2012 | 09:48 AM
Zagohhr's Avatar
I received it mike! Working on it is already in process. I´m going to drain the radiator and open the water pump plug.... And then re-add coolant.
I´ll let you know if I had success
Old Apr 7, 2012 | 10:14 AM
Sounds good Juan.
Old Apr 7, 2012 | 11:18 AM
Good luck Juan, we're rooting for your success ! Hope it goes well for you.
