motor mounts
Does someone know how far the back of the edge of the air cleaner top is from the edge of the cowling on an hhr with good motor mounts?
Thanks |
No.... But if you look in your passenger wheel well there should be an access hole with the head of a bolt in the middle of it. If the head of the bolt is lower, then your upper mount is toast. Try a power brake test to check the mounts. You can also use a pry bar.
Originally Posted by aradmahogany
(Post 845825)
And look for cracks in the transmission mounts.
Originally Posted by Oldblue
(Post 845880)
I’m thinking. I haven’t had mine out yet to inspect it.
https://www.chevyhhr.net/forums/prob...problem-60373/ |
