A new maintenance item that I will be inspecting
Old Jan 16, 2014 | 06:55 AM
Lucky's Avatar
A few weeks ago my 08 hhr did some strange things when I started it up in -14 deg weather. The car made some clicking noise under the dash when cranking then my security light stayed on for that entire key cycle.
I passed it off as just one of those weird weather problems until yesterday when I started my car to go home from work and it happened again. This time it would not crank and my dash gauges and running lamps flashed rapidly. The first place I looked to investigate my problem was the battery connection at the under hood fuse box.
Sure enough the battery cable would move when I gave it a wiggle then my lights stopped flashing the clicking noise stopped and the car started right up.
So I will be checking and servicing this connection as I do my regular under hood service maintenance from now on.
Just passing on this experience so as it may help someone in the future.
Old Jan 16, 2014 | 07:03 AM
Thanks for the tip Lucky, will check them today.....
Old Jan 16, 2014 | 07:59 AM
Good tip Lucky.
I do recall some other members here that found this same loose connection.
As far as people posting about weird electrical problems, maybe our responses should start with: "Check the underhood battery cable connection 1st."
Old Jan 16, 2014 | 09:33 AM
Silverfox's Avatar
WOW Lucky,
That was a Hail Mary fix.
I am impressed .....
Thanks for passing the info along.
It's kinda the grown up version of the loose fuses ...
SF
Old Jan 16, 2014 | 10:17 AM
I check mine every other oil change! it has been loose before but not after I started this service check last year.
Old Jan 16, 2014 | 03:39 PM
Lucky's Avatar
Originally Posted by Silverfox
WOW Lucky,
SF
I checked the battery cable first because of what I have read on here over the years. This site is a great source of information. Even a blind squirrel finds a nut occasionally.
Old Ray
Mar 7, 2008 06:56 PM
courthousedeb
32
Aug 11, 2006 07:12 AM
