Oh Gregg, P0301
Oh Gregg, P0301
So I have this odd issue. Its been going on all year, and first happened a few months ago and then just happened this past Wednesday. To date, it has only occurred the two times.
Its a cylinder 1 misfire, but it only occurs under heavy acceleration (3/4 throttle and above) and it will sometimes happen sometimes not. The code is never set, it is only stored as pending, and goes away after a drive cycle or two. to stop the misfire I have to shut the car down and restart. There are ZERO -problems after restart, like nothing happened.... I already replaced all spark plugs and the coil on that cylinder.
Data log revealed no issues with fuel trim, cat temp, O2 sensors, or the like. I have no clue what it could be. My dad suggested a bad ground perhaps? where is the ground located for the injectors,.... if it exists.
A/F ratio is perfect as well. I attached some pics showing the live data taken the next day. First pic is just cruising and the second is a screenshot right after a short acceleration at a little over half throttle.
I am at a loss.After the misfired occurs the car seems to go into a limp mode where it wont rev past 2500 RPM, which I found when trying to move over tto the side of the highway to pull on a side street.
Any advice on where I might want to look next Gregg runs great otherwise and like I said I have even tried testing it before and it just doesn't happen. Hell, I changed the plugs and coil pack right after the first instance, took the car out, warmed him up, and floored it for the first time ever and it didn't happen.
