Options for Front Wiper Blade Replacement
Anyone know if it's possible to remove and reinstall wiper arm so they rest lower. Mine especially on passenger side rest on the glass when off. I see other HHR wiper arms rest the same way. I can live with it but if they can be reset lower it would look better. Whatever happened to hideaway wipers anyway?
However, I warn you about going to low, the wiper will hit the hood when you put the wiper in the up position and create a little nick in your paint. Mine came too low when I bought it, I didn't know about the problem, and i ended up with a chip in my hood.
Hideaway wipers cost more, and the people who designed our car was cheap.
The problem with refills is that all the dimensions need to be exact and the only way to do that is go back with same store and same style of blade. For instance you have wiper A and go get refill for Wiper B it may work but chances are that it will not perform like it should and is a safety issue.
yes you can adjust them and if you look closely at your windshield you will find little marks where they should be aligned. You pop the little black cap off of wear it pivots, undo the bolt and adjust. Since i had the problem below, I had the dealer do it.
I have the paint chips on the hood from both sides from me lifting the wipers to clean the windsheild....
And I have not seen refills at the normal parts stores for years, maybe at the dealer...
Trico NeoForm NeoForm 18-Inch Beam Wiper Blade
$17.69
Have had them 2 years and have not replace them yet. What helps out is rainx bug wash in the washer and it treats the windshield with rainx
$17.69
