Panel, removal of commercial service goodies
Old Feb 22, 2014 | 04:36 AM
pinballcollector's Avatar
I just picked up my 09 Panel last week. I would like to remove the safety cage from the rear hatch glass. Has anyone removed the interior trim panels from the hatch? Just wondering how much time is involved, any surprises along the way, etc.
I also want to disable the backup alarm, it's pretty loud and draws a lot of attention!
Thanks
Old Feb 22, 2014 | 06:28 AM
Lucky's Avatar
The rear hatch panel is fastened with plastic fasteners. Pop the hand hold cup from the bottom of the hatch then there are two push buttons at the bottom. Push the center of the push button in and it will click then you can pull the fastener out. The rest is just pull trim from the hatch and the plastic clips will release.
Old Feb 22, 2014 | 06:33 AM
Lucky's Avatar
Here is a diagram
Old Feb 22, 2014 | 06:49 AM
A little BEWARE.
The snap in clips can be pretty snug and hard to get to release. Don't grab the trim panel in just one place and start pulling. You don't want to damage the panel and the plastic nubs the clips mount to.
Try to get 2 seperated hand holds and pull with a little rocking motion.
Old Feb 22, 2014 | 06:43 PM
Fox Hat's Avatar
If your are disabling a back up alarm and not used to the HUGE blind spots you may want to consider ALWAYS backing into a spot so you can "just " drive out.
Old Feb 22, 2014 | 06:53 PM
the back up alarm should be wired to the back up lights access panels are in the back on the L/R side kidney bean shaped.
Old Feb 23, 2014 | 06:01 AM
It sounds like a job best done in warmer weather, I don't want to risk breaking anything with the plastics being brittle and cold. Thanks for the info and diagram! I may leave that backup alarm after all, I've already found backing up into traffic to be a bit tricky. We have angled parking on the main street where I live, and reverse lights on or not, people just don't slow down to let you out most of the time. I've seen a few rear enders over the years.
Old Mar 15, 2014 | 02:55 PM
mongo's Avatar
I (heard?) a New York back up alarm last summer....
Put the car in reverse and a recording on a loudspeaker says "Hey! I'm backin up over here!"
Old Mar 17, 2014 | 07:44 AM
papa_jo's Avatar
In the south "Hey Ya'll get your a$$es oughtadaway"
Old Mar 17, 2014 | 09:14 AM
BQS4's Avatar
Nahhhhh, down here, the speaker would say " 'mon back"
ecl
Mods - Interior
17
May 2, 2018 09:54 PM
Telemicus
10
Apr 13, 2010 08:17 AM
Ratracer
Sep 1, 2009 08:14 AM
20vtguy
Oct 31, 2007 04:25 PM
Feb 6, 2007 01:23 AM
