PCV Location or Existance
Old Sep 17, 2024 | 05:51 PM
Fierojo's Avatar
I realize that the PCV is an integral part of an engine’s emissions system but on my 2011 2.2L I can’t find it. Looking in parts books all I can find is a hose that’s labeled “PCV hose”.
Is the actual PCV valve part of the cam cover? Am I missing something?
Thanks for your help.
Fierojo
Old Sep 17, 2024 | 06:18 PM
Lonwane's Avatar
Yes it is,
There is a hose connecting the cam cover to the air inlet just before the throttle body.
Old Sep 17, 2024 | 08:05 PM
greg8453's Avatar
Operation CHARM: Car repair manuals for everyone.
Home >> Chevy Truck >> 2011 >> HHR L4-2.4L >> Repair and Diagnosis >> Powertrain Management >> Emission Control Systems >> Positive Crankcase Ventilation >> Service and Repair
Positive Crankcase Ventilation: Service and Repair
Positive Crankcase Ventilation Hose/Pipe/Tube Replacement
Removal Procedure
1. Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement (Service and Repair).
2. Reposition the positive crankcase ventilation (PCV) hose clamp at the camshaft cover.
3. Remove the PCV hose from the camshaft cover.
Installation Procedure
1. Install the PCV hose to the camshaft cover.
2. Position the PCV hose clamp at the camshaft cover.
3. Install the air cleaner assembly. Refer to Air Cleaner Assembly Replacement (Service and Repair).
pro multis · About Operation CHARM
Old Sep 17, 2024 | 09:03 PM
Fierojo's Avatar
Is there any maintenance that can be performed for the PCV valve inside the same cover? Does the cam cover have to be removed for that maintenance?
thanks
Fierojo
Old Sep 17, 2024 | 09:38 PM
I don't think there's is actually a valve. The engine vacuum provides Positive Crankcase Ventilation through the hose.
The 2.0 turbocharged has a valve. It is needed because, during boost, there is no vacuum, but positive pressure in the intake manifold.
Old Sep 17, 2024 | 09:42 PM
Lonwane's Avatar
Not that I know of other than to verify that it is not plugged inside than cam cover.
If you remove the cam cover you can remove a set of screws and a cover plate and see that the PVC is just baffles to help keep the oil in the engine.
That's in early 2006 engines, the ones with an oil/water heat exchanger.
Old Sep 18, 2024 | 09:44 PM
greg8453's Avatar
Home >> Chevy Truck >> 2011 >> HHR L4-2.4L >> Repair and Diagnosis >> Powertrain Management >> Emission Control Systems >> Positive Crankcase Ventilation >> Description and Operation
Positive Crankcase Ventilation: Description and Operation
Crankcase Ventilation System Description
General Description
A crankcase ventilation system is used to consume crankcase vapors in the combustion process instead of venting them to atmosphere. Fresh air from the intake system is supplied to the crankcase, mixed with blow by gases and then passed through a calibrated orifice into the intake manifold.
Operation
The primary control is through the positive crankcase ventilation (PCV) orifice which meters the flow at a rate depending on inlet vacuum. The PCV orifice is an integral part of the camshaft cover. If abnormal operating conditions occur, the system is designed to allow excessive amounts of blow by gases to back flow through the crankcase vent into the intake system to be consumed by normal combustion.
Results of Incorrect Operation
A plugged orifice may cause the following conditions:
* Rough idle
* Stalling or slow idle speed
* Oil leaks
* Sludge in engine
A leaking orifice may cause the following conditions:
* Rough idle
* Stalling
* High idle speed
Black Rose
Feb 1, 2026 07:13 AM
RJ_RS_SS_350
"How To" Tutorial Library
10
Dec 16, 2024 11:14 AM
SC_HHR
Mar 7, 2022 04:32 PM
pdmorris1
Aug 10, 2017 06:37 AM
hhr06NJ
2.2L Performance Tech
Oct 2, 2014 08:42 PM
