Question for those who have replaced timing chain
Old Jan 5, 2023 | 07:52 AM
  #31
This is getting very close to the trolling line.
Old Jan 5, 2023 | 08:33 AM
  #32
greg8453's Avatar
Originally Posted by Lonwane
When my chain started heading south the only thing I noticed was the rattle at start-up.
Once started, the engine, fuel mileage and perfomance were 'normal'.
That is the phasers. Phaser rattle will also stretch the chain faster than normal. When doing a timing set it's advisable to do the phasers as well.
Old Jan 5, 2023 | 09:56 AM
  #33
PulpFriction's Avatar
Originally Posted by mongo
... my question was more about how much does a stretched chain affect performance.
I thought the answer to that was implicit in my reply #12 which suggested a number of better explanations for the change, but to be more explicit, no, even if badly worn, the timing chain/guide/tensioner system won't cause a performance problem until it actually jumps time. The usual warning is excessive noise, especially on startup. (Occasional slight rattle on startup is normal and will typically go away when the tensioner indexes to the next ratchet.)
If you're lucky it will only jump a tooth or two and likely cause throw a code without bending any valves. (But I'm not convinced that with VVT, jumping just one tooth will always immediately throw a code, as the closed loop could sufficienly compensate.)
If you're unlucky, a guide will break, the chain will break, the valves will bend, and the crackcase will be full of shards from the guide.
Old Mar 21, 2023 | 12:13 PM
  #34
Rocket Dawg's Avatar
I have a 2.2 with 213k on the odometer. Original timing chain. Is this engine hard on timing chains. A little history here, car was purchased with 155,000 miles on it in 2014. Its a 2011. So 1000 miles a week for the first 3 years of its life. Obviously highway miles. I may just have this done or is it a fairly easy job? I can wrench for sure. I change oil by miles, not by the reminder. 4000 and its new oil time. I've replace the VVT actuators, easy job. thanks
Old Mar 21, 2023 | 12:21 PM
  #35
Rattling on cold start, codes or, pop the valve cover off and use the MKII organic light sensors on the chain; ANY slack or missing plastic on the top chain guide is bad .
Not a horrible job with patience and time.
Old Mar 21, 2023 | 01:23 PM
  #36
No rattling at start up. I'll look into it though, thanks
Old Mar 21, 2023 | 01:35 PM
  #37
Just this much slack caused cold start noise and codes.
68Chrgr
Maintenance and Upkeep
25
Oct 4, 2025 07:33 AM
will1528
Feb 26, 2022 02:42 PM
Radco
Feb 13, 2022 09:57 PM
reelescape
Jun 3, 2014 05:46 PM
codered3232
22
Mar 6, 2012 09:01 AM
