Rattle in front end -- like someone got married and strung cans to the car
Old Jun 19, 2021 | 12:21 AM
chevroletlover's Avatar
As the title says. This is a 2011 HHR LT, and it's not a subtle sound. It occurs when running over small rough patches in the road. It sounds like it's coming from the right front, but I'm not sure. I'm not good at working on cars. Took it to Firestone and they were useless.
Based on my searches on this forum, I'm thinking maybe sway bar links?
Any ideas how to get this diagnosed and fixed, and the possible cost?
Old Jun 19, 2021 | 12:33 AM
Check my signature for a link to how to diagnose the different noises these buggys can make.
Old Jun 19, 2021 | 07:01 AM
Things that make noises, like those tie rod ends, upper engine mount, hubs, worn brake pads, strut bearing plates, steering rack pinion worn Swaybar bushings, LCA’s rear bushings, broken air filter box bracket.
These are all places to investigate. Some shops will try to get you to spend a lot of money, most times you can fix it yourself.
Old Jun 20, 2021 | 12:43 AM
How was Firestone useless? Wanted money to look? Didn't hear anything? Quoted $$$$$$.
There are other shops.
Old Jun 20, 2021 | 01:28 PM
No, they were reasonable about everything -- only charged me for an oil change. They just couldn't diagnose the problem. They thought I should take it to a body shop, and they thought parts of the body were loose. I don't think that's the case. I'm actually starting to think the sound is all in the hubcap.
Old Jun 20, 2021 | 02:09 PM
Have you considered removing the hub caps? And the front bumper cover if it’s not installed correctly can rattle. So can a loose fuse box
Old Jun 20, 2021 | 09:55 PM
If something is loose enough to make that much noise you should be able to find it with your hands. Is it impossible to touch things? If the engine is off there is no danger involved.
Old Jun 22, 2021 | 09:51 AM
Silverfox's Avatar
It might be helpful if you give us the mileage ...
SF
Old Jun 22, 2021 | 10:01 AM
Silverfox's Avatar
I would remove the wheel covers one at a time so if it is the problem you will know which wheel cover it is.
Also be very careful when putting them back on that you do not over tighten the bolts.
Use the same tightening pattern that you use on wheels.
Check the condition of the gasket attached to each cover and make sure they are in place when you install.
SF
Old Jun 22, 2021 | 11:36 AM
Murph's Avatar
get some weight on front bumper push up on down sharply then
jacks & enough jack stands to lift right front for shimmy , pull & push may render a clue
