Rear brakes
Old May 11, 2016 | 01:59 PM
ONELON : "I understand you know that the friction between the pads and the drums will wear the pads down and free the wheels after driving it a few miles." yes it will - and you will end up with overheated drums, possibly warping them if not catching something on fire.
If it is true that your mechanic said: " As far as tightening the brakes too much, he says it's fine. As long as you can move the wheel with your hands they're good. " - then you really need to find another mechanic.
I'm out of this one.
Old May 11, 2016 | 07:45 PM
alexrckid's Avatar
sounds like that action would make the brakes a tad bit tooooo tight. and, shoes, not pads....
Old May 12, 2016 | 01:00 AM
onelon's Avatar
Looks like this thread got a little out of control....
Anyway, I got home after school and hoisted the car up. The rear wheels gave me a good 8 or 10 spins, both sides. Apparently the measurement of "too much" or "too tight" varies a between individuals...
Old May 12, 2016 | 07:28 AM
8 to 10 spins it a bit much, it should be 3 or 4!
Old May 12, 2016 | 07:58 AM
One of the parts of the procedure that is often forgotten is the centering of the shoes.
After you think you got them adjusted you step on the brake pedal to center the shoes, then check the adjustment again. Usually they will be looser then.
Old May 12, 2016 | 11:41 AM
onelon's Avatar
I can live with that. Before working on the brakes it would give infinite spins.
Old May 12, 2016 | 11:44 AM
onelon's Avatar
I did do it. I stepped on the breaks to center them like the video shows. The I spinned the wheels and got 8 spins
Old May 22, 2016 | 10:19 AM
dr_fosg8's Avatar
I think it is safe to say that the rear brake system on the HHR is poo. I have stopped bothering to adjust mine about 50,000 miles ago and have had no problems stopping at all. Even when properly adjusted the just dont add much to the system.
Old May 22, 2016 | 11:28 AM
But... poorly adjusted they make the fronts do more than they are designed for=failure.
The number one cause of "warped" rotors.
Old May 22, 2016 | 04:34 PM
And rear end collisions!! Those rear brakes need to be adjusted correctly!!
The rear brake design isn't poo!!! It's the auto adjust mechanism not set or lubricated correctly!!
