Rear window trim at top of door leaves a strek on glass.
Rear window trim at top of door leaves a streak on the glass.
Hey all.
I have washed my HHR a couple times now, and no matter how much I try to clean this area, the rear left window trim, it still leaves a trail on the glass after the window is opened and shut.
Even after a few days and the car is completely dry, this still happens. It must be some residue of something that is on the inside of that black trim piece. Any thoughts on how to clean that off without having to remove it?
Thanks
Corey.
Thanks
Corey.
Corey- The ability for you to "edit" your post is possible for only a few days, then it is set. & the Edit button goes away..
Click on the "Edit" button on that 1st post, then select Go Advanced
This will open the post, so you can revise the title..(should you still feel the need)..
Ask me how I know..
Ask me how I know..
Ask me how I know..
Ask me how I know..
Thanks a bunch for that. Fixed the typo and some bad grammar....lol
Cheers.
Corey.
