Removing rear door
Old 08-25-2018, 10:38 AM
Cliffs51's Avatar
Removing rear door
I did a search on how to remove rear doors but didnt see anything. Anyone know if a how to or if there is anything critical to watch out for?
​​​​​​​Thanks in advance
Cliffs51 is offline
Old 08-25-2018, 11:19 AM
gio89kid's Avatar
The rear doors in the back should have an electrical disconnect in the seam and then just unbolt it I believe, but I have never done it before.
Same with every door actually, usually there is an electrical disconnect and then you just unbolt it.
gio89kid is offline
Old 08-25-2018, 12:20 PM
Looks simple enough...
Greybeard999 is offline
Old 08-25-2018, 12:37 PM
Cliffs51's Avatar
lol
Yes I mean the passenger rear door. Do you know if the electrical plug is in the door or is it in the center post if the car body?
Thanks
Cliffs51 is offline
Old 08-25-2018, 01:32 PM
Cat Man HHR's Avatar
PM Hells Hot Rod. He parts out HHR's and can tell you.
Cat Man HHR is offline
Old 08-25-2018, 02:23 PM
gio89kid's Avatar
It should be in the car body. Pull back the rubber and disconnect the plug.
gio89kid is offline
Old 08-25-2018, 06:12 PM
Cliffs51's Avatar
​​​​​​​Good idea thanks
Cliffs51 is offline
Old 08-25-2018, 06:13 PM
Cliffs51's Avatar
​​​​​​​Ok thanks!
Cliffs51 is offline
Old 08-25-2018, 06:26 PM
Not really clear but here’s a picture of the rear door harness for the HHR
Oldblue is offline
Old 08-25-2018, 07:24 PM
hellshotrod's Avatar
there easy should take u 2 min to pull make sure u unbolt the door check rod before the hinge bolts as its a pain to put the hinge bolts back in as it wont come off lol ,,, done it ,,, and the doors all work but if u have window switches on the door u may have to change the wiring ,, lmk if u need info thanks dave
hellshotrod is offline
Quick Reply: Removing rear door
