Removing rear door
there easy should take u 2 min to pull make sure u unbolt the door check rod before the hinge bolts as its a pain to put the hinge bolts back in as it wont come off lol ,,, done it ,,, and the doors all work but if u have window switches on the door u may have to change the wiring ,, lmk if u need info thanks dave
Thanks for everyone's help. We just got back from lkq in Daytona with the new used rear passenger door. It was relatively easy to get off. It took longer to get the inside panel and the door wiring plug off.
Now to take off the existing dented door off and replace it with the lkq door. The existing door is dented in where it meets the fender kick panel. I figure its cheaper, ($65), to replace the door than have a body shop repair the dent.
If it's the side door, it's the same as above. Unplug on the Body side. These cars, like most recent ones, are built with the doors off for access. Therefore, when the door arrives to the line, it is fully assembled. It just has to be hung properly, and the electricals should be in the B-pillar.
Slide_Rite
"How To" Tutorial Library
25
Sep 14, 2015 09:49 AM
