Removing rear door
Old Aug 25, 2018 | 07:38 PM
Cliffs51's Avatar
Originally Posted by hellshotrod
there easy should take u 2 min to pull make sure u unbolt the door check rod before the hinge bolts as its a pain to put the hinge bolts back in as it wont come off lol ,,, done it ,,, and the doors all work but if u have window switches on the door u may have to change the wiring ,, lmk if u need info thanks dave
​​​​​​​Thanks Dave sounds easy.
Old Aug 26, 2018 | 01:00 PM
Cliffs51's Avatar
Thanks for everyone's help. We just got back from lkq in Daytona with the new used rear passenger door. It was relatively easy to get off. It took longer to get the inside panel and the door wiring plug off.
Now to take off the existing dented door off and replace it with the lkq door. The existing door is dented in where it meets the fender kick panel. I figure its cheaper, ($65), to replace the door than have a body shop repair the dent.
Old May 25, 2019 | 06:03 PM
Susan McGinnis Hardie's Avatar
Replacing rear driver side passenger door.
We found a door st a salvage yard for $75. Is it a difficult job to replace the door? I read your notes but I am not clear on the electrical.
Old May 25, 2019 | 06:21 PM
You need to disconnect all of the electrical stuff inside the door. And the washer tube. Then pull them through the hole.
Old May 25, 2019 | 07:45 PM
Blue_SS's Avatar
If it's the side door, it's the same as above. Unplug on the Body side. These cars, like most recent ones, are built with the doors off for access. Therefore, when the door arrives to the line, it is fully assembled. It just has to be hung properly, and the electricals should be in the B-pillar.
Old May 25, 2019 | 07:55 PM
Mitchell says the lift gate is different. If you are in possession of the used one it should be a moot question.
Slide_Rite
"How To" Tutorial Library
25
Sep 14, 2015 09:49 AM
orangutanHHR
May 30, 2013 12:40 AM
1HotHHR
May 16, 2008 05:34 PM
GDZHHR
Oct 2, 2006 04:25 PM
