Removing a stick on blind spot mirror
Old Jun 28, 2007 | 04:37 PM
JJ_HHR's Avatar
Question Removing a stick on blind spot mirror
I installed on of those little blind spot mirrors on my mirror. However, it is in the wrong spot and I need to remove it. As inexpensive as they are I'll just replace it.
Is there an easy way to remove the old mirror without damaging the main mirror?
-JJ
Old Jun 28, 2007 | 05:11 PM
jp523's Avatar
try using some wd40 to loosen the adhesive
I would try to use some wd40 to loosen the adhesive. Once it's off clean it well and also use an alcohol pad to get the new mirror to stick well.
Old Jun 28, 2007 | 06:30 PM
Size:  5.6 KB to the site jp523!!!
Old Jun 28, 2007 | 07:02 PM
tsaints1115's Avatar
Use soap and dental floss,pull down in a sawing motion and off it comes. Works for prisoners!
Old Jul 3, 2007 | 06:05 PM
JJ_HHR's Avatar
That worked. Thanks.
-JJ
LawDog88
Jun 2, 2011 07:54 PM
tkfel98
Dec 26, 2010 10:37 PM
Lil Cheney
Feb 22, 2009 07:10 AM
FXM
Apr 28, 2008 07:25 PM
Lee3333
Sep 15, 2006 11:46 PM
