For those that don't know this little noise tip.
Old Oct 3, 2012 | 12:54 PM
IgottaWoody's Avatar
I think they pretty much a standard size..up and down a notch or two..havve a couple pieces from work im going to try out..if they can hold thin composite panels together on a flying machine they surely will work on a plastic car..
Old Oct 3, 2012 | 11:00 PM
SF- I agree with Woody, I know they are the same size on the OD, & length.
Just had both her & my inner fenders off.........Just a way better design on her Mopar...
I'll be looking at the local parts houses first.. But shouldn't cost much @ Mopar..
But right now, I'm dug into another project..
Old Oct 17, 2012 | 03:59 AM
finnhhr's Avatar
heyy this is really great info! i was already freaking it must be something loose in rear suspension, i have also several times repacked the spare compartment.
if my english understanding is correct; you mean one needs to lube the bracket on the tail gate? not the lock, not the latch, right?
thanks anyways this is great fix.
Old Oct 17, 2012 | 09:45 AM
Silverfox's Avatar
I lubed both the latch mechanism in the hatch/door and the proper spot in the latch catch on the rear deck.
The latch catch ( a U shaped piece of round metal ) should be lubed on the vertical area facing you as you are standing in the back of the HHR with the hatch open.
If still not sure what I mean, just slowly close the door/hatch and watch where the latch mechanism attaches. Lube that POINT.
SF
Old Feb 6, 2013 | 09:46 PM
Silverfox's Avatar
Hey Sleeper,
Did you ever get around to installing some Mopar Plastic Fastners to replace all the loose ones??
SF
Old Feb 15, 2013 | 02:48 AM
finnhhr's Avatar
Thumbs up
noticed that when i replaced new rear shocks, the trunk door "clunk" disappeared.
so it might be with the fact when rear suspension gets too loose; the trunk door jumps up and down more... so best fix to prevent the rear clunk is to replace the shocks!
Old Mar 10, 2013 | 01:49 PM
REDSEDANDELIVERY's Avatar
I use well nuts from a Marine Store, 6-32 or 8-32 with a "fender "washer. No rust issues..
Barry Herbert
Aug 21, 2014 10:16 PM
Gsus
Sep 6, 2013 08:42 AM
sumo1
Aug 11, 2009 07:27 PM
vschriver
Jun 20, 2008 09:09 AM
HHR321
Feb 17, 2007 11:18 AM
