Tie rod toe ajustment
Old Jun 14, 2019 | 08:38 AM
davidfr's Avatar
Can anyone give input about how to ajust my right passenger outer tie rod toe after i install a new tie rod end? My front tires still have even wear but tie rod is shot. Thank you
Old Jun 14, 2019 | 08:49 AM
Replacing both sides I hope. Unscrew the old tie rod counting the number of turns or threads that it takes for it to come off. Put the new one on with the same number of turns. It will be close but you'll still need the car put on an alignment rack to get the final adjustment.
Old Jun 14, 2019 | 02:09 PM
Cat Man HHR's Avatar
Thanks George. Simple Math is all you need to get close.
Old Jun 15, 2019 | 03:40 PM
Blue_SS's Avatar
On "experienced" car like an HHR, I would suggest doing both sides and aligning it once afterward, too.
Old Jun 15, 2019 | 04:19 PM
davidfr's Avatar
Did just that. Put both tie rods on. Got it aligned 2 hours later. Even the front end shudder at takeoff from a light has stopped. Put new rear brake shoes and drums on the day before. So far, so good.
Old Jun 15, 2019 | 06:05 PM
Make sure you readjust the rear brakes after a couple hundred miles. HHR's are very finicky when it comes to out of adjustment on the rears.
Those new shoes will center up , seat in and probably need a few clicks to snug them down.
Old Jun 15, 2019 | 07:26 PM
davidfr's Avatar
You bet. I had planned on ajusting the shoes at about 150- 200 miles. Thank you.
Jacob Willingham
20
May 5, 2017 08:03 PM
hurst2001
Aug 8, 2013 07:04 PM
The Curly 1
Aug 26, 2012 08:31 AM
Eldon
Feb 10, 2008 12:40 PM
