Transmission jumping?
Old Apr 25, 2022 | 04:46 PM
Epohlman37's Avatar
Originally Posted by greg8453
Now I don't see a P0302 misfire code in there. Does that come and go?
Your pre-cat O2 sensor is slow to heat up or the heater is bad.
I would look at the actuator for the intake cam not the sensor. Make sure the wiring and connectors are good.
yes the misfire code comes and goes
Old Apr 25, 2022 | 04:47 PM
Epohlman37's Avatar
For the P0010, P0011 you'll need to replace the actuator solenoids. Easy job.
Here's a link- https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Hmm. Don't see a misfire code.
just bought those parts should be here by end of the week!
Old Apr 25, 2022 | 04:48 PM
Epohlman37's Avatar
I appreciate y’all’s help! First time on a chat forum thanks y’all.
Old Apr 25, 2022 | 05:25 PM
Misfires are not urgent... if you can afford to replace catalytic converts.
Old Apr 25, 2022 | 05:29 PM
Epohlman37's Avatar
just did some reading up on the misfires, why do you say that about the catalytic converter? Does it correlate to the misfire? Main concern is still fixing the gears shifting too hard, but if within my price range I’ll take care of the misfire as well.
Old Apr 25, 2022 | 05:45 PM
Originally Posted by Epohlman37
okay cool thanks man, so no idea on the car jumping when changing gears?
Reread post #4. I explained it there.
To explain a little more, the car goes into that "limp" mode scenario because of the codes lit up. It's the onboard computers way of telling you something is wrong...by giving you the harsh shifts.
Old Apr 25, 2022 | 05:47 PM
Epohlman37's Avatar
okay Thank you, that’s my fault for not understanding what you previously said. Well now I’m going to try and fix all the codes I have and see if that helps.
Old Apr 25, 2022 | 07:27 PM
Also, your reader is registering 16 codes. Many are probably the same code multiple times. But you should make sure you see all of them.
Old Apr 25, 2022 | 08:10 PM
PulpFriction's Avatar
P0010 is a problem with the intake solenoid circuit. It could be bad wiring or connectors but it’s almost always a bad solenoid valve It’s probably causing P0011. You’ll get lots of opinions telling you to replace both solenoid valves but solenoid coils do not have a terribly predictable life and I think replacing the other one too is a waste of effort and money with this code. If you were getting P0011 only, that would suggest a gummed up valve, and then I would replace both (and change the oil more often.)
I don’t know too much about P0030 but I would check wires and connectors carefully before replacing the upstream O2 sensor.
For better descriptions of DTC’s more specific to HHR, bookmark this link:
https://www.chevyhhr.net/forums/prob...010-hhr-14259/
Old Apr 25, 2022 | 08:26 PM
So I bought and changed the wrong part then? I tried doing some research online and though I was supposed to change the camshaft positioning sensor which is what I did
I don’t know where you got that info but when talking about Ecotecs SO many people say “sensors” when they’re talking about those solenoid valves, because they’re parroting one another in an echo chamber and have no idea what they're talking about.
