What do I need to Change my oil?
Old Apr 30, 2007 | 07:50 PM
  #51
Black Rose's Avatar
I didn't have everything I needed to do the oil change myself (including the "approval" of Mrs. B.R. ), so when I took my HHR to the dealership to get the armrests and the A/C growl problem fixed, I brought my own oil and got them to change it.
I figured I would save a decent amount of money by having them change the oil.
Well not quite. When you pay for the dealership oil change package, they reduce the cost of the filter to $6. Bring in your own oil, and they charge full price ($12.10 ). Also costs an extra $1 to dispose of the plastic oil containers.
In the fall, I'll be changing it myself.
Old Apr 30, 2007 | 07:57 PM
  #52
johnnypatrick's Avatar
Do like I do and have someone else do it
Hey I don't mind having someone else do it. You only save 10 bucks. Walmart will do it for about 15 bucks. You don't have to jack the car up or mess with disposing if the oil .
I recommend the newer synthetic oil. These small 4 cylinder engines are reved way high and work real hard.
Old Apr 30, 2007 | 08:03 PM
  #53
Black Rose's Avatar
Had 5 litres of Syntec 5W30 put in it today.
I wanted to use Pennzoil Platinum, but it didn't go on sale when I needed it. Now that I have Syntec in there, Pennzoil Platinum will go on sale this weekend
Old May 18, 2007 | 09:43 AM
  #54
Goose's Avatar
Hey BR...did you ever find out if you needed a crush washer?
Goose
Old May 18, 2007 | 09:47 AM
  #55
Black Rose's Avatar
Yeah, you do. It's more like a rubber gasket that goes on the back side of the drain plug.
Here's a visual of it:
http://www.crateenginedepot.com/stor...xGUzyiq6QJU8ZJ
Old May 18, 2007 | 11:20 AM
  #56
Goose's Avatar
Ok thanks...can get those at the dealer right? I used to get the ones for my Matrix at dealer......
Short money?
Goose
Old May 18, 2007 | 11:57 AM
  #57
Snoopy's Avatar
Actually, I now buy the drain plug with the inherent rubber gasket for $1.00 from my dealer. I purchased 2. They don't even sell the gaskets any longer.
Old May 18, 2007 | 12:35 PM
  #58
Goose's Avatar
Ok....I'm a bit confused...is the gasket now part of the drain plug? If so do you need to buy a new drain plug each change
Goose
Old May 18, 2007 | 12:41 PM
  #59
Snoopy's Avatar
Up to you, your dealer and pricing.
My dealer just did away, with removing the gasket and replacing the gasket. Faster to just install a new plug with the inherent gasket and it probably removes the possibility of gasket tear, etc.
For me...buy a gasket for $1.00, or buy the entire plug with gasket for $1.00.
Old May 18, 2007 | 01:44 PM
  #60
Goose's Avatar
aha..well I guess If I could get both for the same price it makes sense...seems like a waste of a perfectly good drain plug though doesn't it?
Goose
