What sensor is this?
Old Aug 30, 2024 | 01:26 PM
mikeike's Avatar
Having hardest time figuring out what this sensor is..needs replacing as I noticed leaking. 09 hhr 2.4 lt. Ty
Old Aug 30, 2024 | 03:31 PM
Here is a good diagram, post #7
https://www.chevyhhr.net/forums/main...82/#post764063
well now I don't know, that diagram all seems to be internal stuff.
This diagram shows external stuff, but I don't see anything where your picture shows.
Old Aug 30, 2024 | 03:44 PM
Maybe #62?
Old Aug 30, 2024 | 03:45 PM
mikeike's Avatar
Found this and a couple other diagrams but none point to this location..this one is in next to oil filter below the wide thermostat hose
is this tranny related?..not too far from tranny fill plug
Old Aug 30, 2024 | 04:07 PM
Yes, transmission. The back edge of the engine is the right edge(from the view in your picture) of the oil filter housing.
Old Aug 30, 2024 | 04:14 PM
Only thing I can remember in that area is the transmission cooler lines or the transmission wiring harness.
Old Aug 30, 2024 | 04:16 PM
mikeike's Avatar
Searched for (all/most)transmission sensors via auto parts website and compared with photos but none resemble this one
Old Aug 30, 2024 | 05:18 PM
Isn’t that diagram backwards for what you’re looking for ? The side you can’t see would show the sensor you’re looking for ?
Sorry. I only had a 5 speed. Forgive me if I’m viewing this wrong.
Old Aug 30, 2024 | 08:18 PM
Yes, backwards. The VSS is on the back of the trans.
I can't think of anything that could drip oil around that area, more likely drip from filter changing.
Old Aug 30, 2024 | 09:28 PM
mikeike's Avatar
Solved.
Mine is an 09 hhr 2.4..its my understanding that this year and up no longer have oil coolers(which checks out;dont have one). I dont know the exact name for this part but had local shop check it out and yes it is a "transmission connector" not a common sensor. Tranny shop to check this next week. Wish me luck lol
