Mods - Engine/Exhaust EngineCompartment/Exhaust Discussions. (Non-Performace)
Oil Pressure Guage
Old Apr 19, 2013 | 02:57 PM
IgottaWoody's Avatar
No..do a stand alone setup..the block sensor is voltage regulated and tied into other systems so if you splice in you will change the readings and the brain boxes wont like that.
or..go with a multi gage and plug and play to the OBD port under the dash
Old Apr 19, 2013 | 04:33 PM
My OBDII software does not supply oil pressure (ScanmasteELM). Do you have any specifics for the HHR Woody? Like pin number etc.
Old Apr 20, 2013 | 10:59 AM
No..but after thinking about it..I believe it was an add on feature which required a sending unit..my bad
Old Aug 23, 2020 | 02:49 PM
lew's Avatar
lew
Mechanical oil pressure
Need to know the best location for a mechanical oil pressure fitting for a 2009 HHR 2.2 liter. "T"ing from the stock sending unit is not an option. The gauge kit came with a 12MM to 1/8" NPT.
If anyone can explain in lay-man terms where to insert the sending unit plug for the best gauge reading results, it will be appreciate.
I did look at some old threads and could not follow the information (not a mechanic).
Old Aug 23, 2020 | 04:20 PM
The only place I know of is the stock location. Why not get pipe thread adapters?
Wolfblitz
Mods - Interior
18
Jul 16, 2012 04:03 AM
hogwild
Feb 24, 2008 06:37 PM
pjtaxi
Jun 4, 2007 05:31 PM
pjtaxi
Sep 29, 2006 08:26 PM
